I can’t find Stremio in Filesynced or Unlinked. Can you point me in the right direction?
It’s in unlinked and the rapid app installer.
Thanks for the timely response!
Dracoo is correct, in unlinked it’s in library 12341234
Thanks, I found it in the rapid app installer. I had been through unlinked a couple of times. There are lots of programs with that code.
I can’t get TeaTV to play anything.
Try stremio then, I don’t know why you can’t get it to play, what happens? Did you go.through the guides to setup an external player?
“I can’t get TeaTV to play anything.”
Did you update it? Did you install the mandatory TPlayer?
This topic was automatically closed after 6 days. New replies are no longer allowed.
Lost all my feeds on St r e m i o last night Pacific time about 8:15. Came back on this morning.
