Is Top EPG compatible with IPTV Editor or iMPlayer?
I remotley manage IPTV for some family members using iMPlayer and IPTV Editor to act as a middleware to organize categories, channels, adjust settings, etc.
Is there a way to use Top EPG with either of these applications? It has a lot more coverage for Strong than IPTV Editors built in EPG (I use Tivimate along with Top EPG on my TVs).
If not has anyone had any success with other EPG providers that are specifically meant for Strong?
Never heard of Top EPG. Lots of information in this thread’.
https://troypointinsider.com/t/epg-for-iptv-explained/138220
If you are referring to MyEPG.top I use it with Strong and it is great IMO. I do not use any editor though
Are you using it on implayer?
IMPlayer supports multiple EPG sources simultaneously. You can combine a primary global EPG with a specialized one for sports. The iptv-org/epg repository on …
Following link is from a IPTV service provider branding service as it’s from implayer - this has nothing to do with App developer
