IPVanishVPN help
Hi there. Since purchasing IPVanish I have noticed everything I watch is now always buffering ? I use iptv paid service to watch all sports and movies any help would be much appreciated. Many thanks. I’m in the Uk
@Toffeymen23
Welcome to the community.
Probably need to look at your down speeds while its on.
mine does at peak times I don’t think you can do much about it but turn it off, but I,m in the states.
My suggestion is to take the time to test each and every protocol, along with any port options and test different servers. Yes this takes time and testing speeds after every change also takes time. But on many customers after about 30 minutes, I have a picture of which combination provides the best speeds. You may just find a “sweet” spot.
Many thank for you help
Many thanks for your advice :pray::+1:
