IPTV Smarters Pro on Firestick & Android TV
I’m new to the app. I’m able to get it to work ok. I have subtitles turned off in settings, but while watching an NHL game subtitles are on. I can’t figure out how to remove them. They don’t come on on other channels.
I can’t seem to find any user instructions. I’m having trouble stopping a channel to switch to another, among other things
Thanks for any help, Tommy
Could be hard coded in that stream - you may need to find another stream of same channel
Thank You Mike
Has anybody updated to smarters player lite on ios 1.2.6 and now on live tv section when you select a channel it bounces back to your app screen. Its ok on movies and series.
Same thing is happening to me using Smarters Pro on a Hisense Tv with the Google OS. Works fine on my smartphone and computer.
FYI - The latest version of Smarters Pro app which is 4.0.6 is fully premium enabled. I have multiple services installed on it. Of course the Tivimate Premium lifetime for 5 devices for I believe is 33.98 from their site is a great option for premium access.
Good morning Troy Point and members,
dont know if this was posted cause i did search and didn’t see anything that i will ask.
in this IPTV Smarters Pro do they have TV shows and movies on demand with their live tv.
do you recommend. thanks in advance I been looking for good choice for keeping the cord cut.
IPTV apps do NOT have any content - they are just a media player.
You have to find a content provider which you setup on the IPTV app and it should have TV shows and movies on demand with their live tv.
From Troy’s tutorial
I think Amazon is starting to block programs like this. I re-installed tivimate 3 times on my firestick , and the next day it wouldn’t work I decided it to put it on my Onn tv device and no problems since
where can I find a trustworthy Provider or Xtream codes
Become a Patron then you will have access to the locked thread where IPTV providers are mentioned
He’s already a Founding Member and has access.
Thanks Miki I didn’t see the Patron icon and didn’t know. But now I do!
Ya he’s got the big “T” flare.
I’m using IPTV Smarters Pro and have a few different iptv providers. One from Alibaba and OTTOcean.
I’ve never tried to record before. With football season coming up I’d like to get myself ready to record a few games and I don’t see any recording options with either one of my IPTV services in Smarters Pro.
Do I need a new provider or player?
This is what I found. I don’t use Smarters pro. I much prefer TiVimate.
For scheduled recordings:
Access the Electronic Program Guide (EPG)
Browse upcoming programs
Select the show you want to record
Tap “Schedule Recording” or the clock icon
Confirm the recording schedule
The system will automatically start recording at the scheduled time
I’m trying to install smarters pro on troypoint but the keyboard covers the m3u line so u can’t see what you are typing. Can u move the keyboard somehow.
I installed Tivimate… now I can record.
Thank you
Good evening I just installed the IPTV smarters pro app everything installed correctly I have entered everything but in the video it said something about weight on email for the URL does anyone know how long that email will take to get
