📺 IPTV Services Detail
Been usin KEMO for years seldom goes down and fast ticket answers. Wanted a back up so I tried Smart iflix. Big mistake worse customer service out there. Sticking with KEMO
I asked for just USA channels too and got everything, apparently Alibaba doesn’t just give you USA channels. But there is a way you can filter out the channels you don’t want to see through Tivimate. When you’re on the EPG, go to a channel and hold down on select until you see the side menu appear. Go down to the bottom until you see group options, click on it, then go to manage groups and you can turn off the channel groups you don’t want to see.
Isn’t settings, playlist and then manage group better to turn off unwanted channels?
Can you pm me as well?
I used EagleCast on my own Tivimate. They are very responsive. Rarely buffered. Depending on needs, definitely an extra solid provider.
Been using Private IPTV Access for over a month. Overall, it’s been solid. Don’t like that they haven’t responded to any of my messages. No catch up but I use VorteXtreams for that. Occasionally, a channel will freeze while the audio continues (tends to fix itself in about 5 seconds or so… else, I switch off the channel and come back). 4 connections for $18 per month or $85 for 6 months with a discount for using bitcoin.
Another security measure that is likely beneficial is to change the DNS on our phones, laptops, tablets, and wireless routers (I always use a separate wireless router from the modem that my ISP supplies). Lots of videos on YouTube that shows how to do it and which DNS to use or how to set up our own).
I’m checking into this …
Hello. Please PM me as well with the IPTV rankings. Thanks
I guess that works too.
b2bmedia dot pro. Been pretty good find has active telegram
If anyone is using mega they have disabled some DNS links. Mine was one of these, I contacted Amber last night and in under a minute she or someone got back to me with a new DNS.
:warning: The mexamo.xyz DNS has been permanently suspended.
To ensure smooth and stable service, we have replaced it with a new DNS.
:white_check_mark: All new lines will automatically use the new DNS.
:counterclockwise_arrows_button: For existing lines, the new DNS is available directly from the panel.
:gear: If the service does not work after updating, please generate a new DNS from the panel.
Thank you for your understanding and cooperation.
— MegaOTT Team
This morning they posted about a Samsung one being removed.
:warning: Please be informed that the LG/Samsung DNS [http://rmtil.com] has been permanently suspended.
To maintain stable and uninterrupted service, it has been replaced with a new DNS.
What is the message again to use in the chat when ordering from Alibaba?
I’ve gotta save this somewhere that I can find it again easily!
Info on vortex?
Type url they gave you into http://m3u4u.com
U can edit all the channels and groups yourself.. Make the list and channels how u want.. Add and hide groups and channels.. Then they generate a URL to input into tivimate…and they update every day
pm sent
I also use IT tech basics and Amber baby. Very pleased with Both. Go Patriots!
Looks like a reseller of strong8k.
I would like a referral as well, if you don’t mind. My service is on the brink! Thank you
Has anyone ever managed to compile a list of original IPTV providers that excludes resellers?
a lot of services sell to resellers only .
