Can someone private message me with a great IPTV provider that has 3 connections and has no buffering technology?
I’ve been searching forever and all I can find is 1 connection.
Any help would be greatly appreciated
Thanks
Most of them offer multiple connections for an added ‘donation’.
Ok, I’m looking for one that other people have tried and recommend. The one I’m using now and others I’ve used in the past buffer like crazy.
And I’ve troubleshooted on my end. It’s not my internet or set up.
even the best of the best will buffer some its the nature of the beast i have had expericane with more than most people and no buffering ever is a unicorn
Take a look here.https://troypoint.com/iptv/
Sounds like you need to go threw this. Also it depends on there network. Iptv will always habee issues if not gotten legally. Depends on a few things but the biggest issue is server congestion.
Ok,I’ll have a look. Thanks for the info, and fast reply
No buffering technology is a made-up marketing term that IPTV providers have been using/pushing lately.
if you read the link dracco sent there is no such thing a zero buffering there are too many outside things that can affect it – a main one is how busy your iptv servicers are the more users the more issues you can have all the speed in the world but if the bandwith is clogged up it buffers
so i look for little know nor on everys list when seeking a provider
You might try ITTech Basics and/or TyphoonLabs. Both have been mentioned here at Troypoint. I’ve subscribed to both for over 6 months after getting some recommendations and both work very well with virtually no buffering. Keep in mind your signal strength and speed from your internet and vpn will govern your download/upload speeds. Typhoon provides up to 5 connections for $15 per month. ITTechBasics provides anywhere from 1 to 5 connections at different price levels.
I had buffering issues too and found it was the vpn location… as soon as I switched locations from Detroit to Chicago… no buffering… what left me scratching my head is both locations had the same download speed 90 - 100.
Good evening. I had the same issue with Tivimate PRO but not sure I think they did a update and now I can run 3 TV’s at the same time and zero buff when all are running. I know xtremehd does cost more than others i would have to say its now working great. Also I’m on the east Coast and VPN is set for Canada.
This topic was automatically closed after 2 days. New replies are no longer allowed.
