Installing Cinema HD V2 2.3.6.1
How Can I download the older version of Cinema Hd. (2.3.6.1)? the newer version (2.4) does not seem to work as well when I search
Don’t bother . Cinema HD is no longer .
Try other apps such as Nova TV , Bee TV , Film + or Tea TV. I Personally like Film +.
Good luck
Pirate is correct. The Developer has abondened any development of CinemaHD. Of course you can search the web for older versions if you like. I’ve been using Stremio for years for Movies And Series, and it’s always being updated and maintained. It’s my top recommendation.
how long do you think cinema hd will continue to work? Mine is still going strong
Until the links expire . You’re better off just switching to another app so that you will get the latest movies & shows as there won’t be anymore programming added to Cinema .
Good luck
With the new api and procedures not sure. If you use a debrid service probably wont work for long. But cinema is no longer id move on. These topics in this are always going to be the same.
