Installation Issue - "Repository Not Found" Error with Diggz Xenon Build
Good afternoon, Troypoint team,
Issue Summary: I’m experiencing a persistent error when attempting to reinstall the Diggz Xenon Kodi build. The installation process completes successfully until the final step where I select “Install from repository,” at which point I receive a “Repository not found” error message.
What I’ve Tried:
  • Attempted installation using the primary link from your website
  • Downloaded from all three alternative URLs listed
  • Uninstalled and re-downloaded the addon multiple times
The error occurs consistently across all installation sources.
Current Workaround: I’ve temporarily installed the Enigma Silvo build as a stopgap measure. However, I prefer Diggz Xenon’s skin and interface options.
Questions:
  1. Has this repository issue been resolved recently? If so, could you point me to the updated installation guide?
  2. Is there currently a working installation method for Diggz Xenon that I may have missed?
  3. Are there any known compatibility issues with current Kodi versions?
Thank you for any guidance you can provide.
Best regards,
Geeham
14 posts were merged into an existing topic: How to Install Diggz Xenon Kodi Build
