How to Setup TorBox in Kodi, Stremio & APKs
Originally published at: How to Setup TorBox in Kodi, Stremio & APKs
TorBox is a fairly new debrid service that touts no user logs, low price, and ability to share accounts with family and friends. You can think of a debrid service as a “middle-man” that downloads files at blazing fast speeds onto their servers and then provides quick retrieval for the customer. These services usually have…
Greeting,
I was wondering how many devices can use my TorBox subscription on?
Can I Use My Account With Many Different IP’s?
TorBox can be used anywhere!
Updated over a year ago
TorBox doesn’t track your IP at all. You can log in and download files wherever you like, your grandmas house, your girlfriends place (no way you actually have one though), on mobile hotspot, at the airport, McDonalds (we know you go daily), or even on a VPN (why are you hiding from the government). There is no restriction on where you log in and download files from. As an extra security feature, you will get a notification notifying you if your account has been logged in on a different device though, so be aware of that.
You can even share your account with others if you like! There is no restriction on how many devices can be logged in at a time, so share it with your friends and family if you want. Just remember that we have a fair share policy, and if we notice that your account has extremely high usage, we will investigate. If you are found to be using our service in an unfair way, then we will disable and ban the account in question (We are more lenient if you have a plan).
Does Torbox run concurrently with Debrid??
TorBox is a Debrid service, just like Real Debrid and Premiumize, along with a few others. You can add them to many addons for scraping sources.
Can TorBox be used with Cinema HD?
From what I’ve seen no it doesn’t but Cinema is just a hacked mess nowadays anyway. I suggest using Stremio instead, best out there.
I switched from RD to PM when stuff happened. For me PM doesn’t work with many APKs even though I’ve configured the key properly. The option is there but it just doesn’t bring up any debrid listings. I’d consider TorBox if I knew it would work
Hello, they have a free trial, credit card not required.
Hey there…I just set up Torbox on Kodi Addons:The Crew, Umbrella, POV. Umbrella may not sort for cached torrents only, but ….The Crew does as does POV. All are working fine…so far
Thanks again, Troy!!! u da best
Can you please explain usenet more deeply as apparently it should provide more resources and older content.
It comes with the Pro level for $10/mth
I normally use Diggz xenon [debrid] - will it work with this or will I have to wait for a while until Diggz catches up
Peter
I just tried setting up the free trial and it’s asking me for my credit card information.
I think I saw a post by them saying they now do require it because a handful of people kept abusing it to make new free trial accounts every day :confused:
Anybody else having issues with the link Troy has shared - it appears their website is down?
Various browsers showing this (and yes, tried via various countries with SurfShark)
welcome-to-our-universe-animated-group-cards
welcome
Nope, it’s working fine. If you have Surfshark, disable their Clean Web feature, which can do some overzealous blocking on the DNS level. That’s why there is an SSL Protocol error showing.
You can always check here if you suspect the site is down:
Unless it’s showing up there, the issue is somewhere on your end.
Ahh freaking MalwareBytes was the culprit - I’d forgotten I had that running. Thanx for the reply.
