How to save recordings in TiviMate to External USB Storage in Fire OS 8 on the 2nd-gen Fire TV Stick 4K & 4K Max | AFTVnews
https://www.aftvnews.com/how-to-save-recordings-in-tivimate-to-external-usb-storage-in-fire-os-8-on-the-2nd-gen-fire-tv-stick-4k-4k-max/#respond
Hi Powerfader, thanks for the information on Tivimate recordings. It worked out perfectly! I ended up using a powered 3 port USB stick and was able to install the USB stick and a Bluetooth mouse in it and then was able to access the system picker and use the mouse to set up the USB access on Tivimate. It’s working perfectly. Thanks again!!
