How to resubscribe to TiviMate?
I need to resubscribe to TiviMate soon . I down loaded TiviMate companion but it don’t work . It wont take my login info or get a new password . Is their another way to resubscribe to the service ?
I would say uninstall your Tivi companion app & reinstall it from somewhere else…& of course, triple check your credentials when entering.
The site is telling me my device isn’t compatible with their device .
I found out how to renew my TiviMate apk But I have one more question . When I renew it will all my mp3 files stay in the app ?
Yes they will, but I would do a backup before you do anything else. Are you just going for another year or lifetime?
I’m going from a one year sub to a Lifetime sub .
When you backup your m3u’s to where do you put then in ? I have several choices .
Whatever folder is convenient for you…doesn’t matter as long as you know where it is when you need to Restore it…probably a good idea to do a backup once or twice a month if you have important stuff on your Tivimate.
I put mine in the “Downloader” app/files. That way I don’t have to “create” any files. It’s also an app I keep on the USB Drive, so don’t need another app.
I backed up my files . Thanks !
ALWAYS DO A BACKUP!
If you do, then you have nothing to worry about.
