๐Ÿš€ How to Install SlimBOXtv Firmware on Android TV Box
If I remember, for superuser to actually show up, you need to have an app that needs it. I had similar issues, but after a few apps, I think Projectivy was one of the ones that used superuser. I donโ€™t have mine hooked up at the moment or I would check how mine is, I remember having issues.
Thank you for your response
i read s905A is the same as s905x5m
1000018259
