Welcome to the Insider!..You are referring to what Troy calls the "Crap Apps " There is a reason Troypoint calls these Crap Apps. They typically are not supported for long and break. Been using KODI for 10 years. Why? Because it works. I would suggest learning either KODI, Stremio and maybe the new guy on the Block Nuvio (I tried it but threw it out) so when the latest Crap App dies you have a backup that works
Ohh and Debrid services are here to stay. They are cheap and they work, Torbox is great
Apparently, you have an access to Onstream and Mobiflix that I do not have.
Can you share that access? Up until yesterday both Onstream and Mobliflex were working albeit buffering before it opened. Today, I had to uninstall it. You just gave a new Downloader code of 8299287. Is this the latest code? I will wait a few hours and reinstall them. In the meantime, can you give me where you are getting these updated codes? Thank you.
This is code for mobiflix 8299287 but I think atm they have server problems but they will soon sort it i hope google has most codes some work some dont
