flixvision is a really good app
Yes but unfortunately, unless you get a âdirect streamâ link, you have to diddle around with the mouseless pointer 1/2 dozen times to finally get the link to play. Donât know why Flixvision does this when other apks donât. Otherwise it would be a great ad-free apk.
I was able to download the same version but after I did the update it will play for 5-10 then will stop working and have to restart the show it happens every 5-10 min throughout the show/movie anyone else have this issue
Yes same here ask showed beta versions downloaded one not playing wellâŚhowever since Sept 9 app is now showing cinema packages not beta down loaded working fine except for subtitlesâŚwhen you download option is play or play w/subtitlesâŚyou click play get good selection of servers it playsâŚhowever if you click play w subsâŚthen click same server it errors out and you must search relentlessly to get subtitled playâŚ
I have APKTime 2.2 and see a new update for Cinema HD Stable v3.3.0 [UnTouched] [Official]
Updated 7-Sep-2024 did ya give that a go. Have to uninstall any version you presently have before installing this copy.
Downloaded newest version working ok
Hello,
My cinema works great but Iâll be watching a show and it stops nearly half way through show what can I do to fix it??
Joe capocci
Welcome to the forum Joe. For your safety I have removed your personal email address that you displayed. Noone needs that in order to respond to your query and is not a good idea to post across the internet. Have a wonderful day.
Iâve installed Cinema v3.3.4. Iâve installed in the way Troypoint said to install it and also installed it from another orovider. They are both acting up. I have real debrid and Trakt installed. If I can find a link that works thatâs a plus. If it plays all the way through, thatâs another plus. If it has sound and no foreign subtitles is not a plus. If it does make it to the end sometimes I can back out like youâre suppose to but other times it just gives me a blank screen and wonât back out. Sometimes it backs out all the way to the home page of Cinema. I was not having any of these problems with the older version. I tried to go back to it but it wonât let me login to Trakt.tv. I use Surfshark as my vpn. Iâm in the USA.
If anyone could help me with these problems Iâm having with the new version, it would be greatly appreciated.
Where did you find the Cinema HD Stable V3.3.0[UnTouched] [Official] Udated 7-Sep-2024? I was just in Apktime and that was not there. I was following Troy 's instructions again but the untouched version is not in Apktime.
I will do some searching for ya.
Thank you
Give this a go. Be sure to use 3.3.4 stable.
Miki, when I put the code in for the one you suggested it told me it was no longer available. I kept reading and found one directly from the site but itâs beta. Iâve never used beta before. Im on a 4k max. Whatâs different about beta? It sure takes up storage.
Papa S never heard of linktree. How do you use it with a firestick 4k max?
Beta means it may have conflicts and not work the best. But then it may work perfectly.
Is it a beta format?
I used to follow Kevin Porteous.
Itâs working fine so far. Thanks for your help.
