I tried everything that I can possibly think of. I have tried clearing data and cache, I have tried factory reset on my Firestick, for some reason when I open cman builds it doesn’t go down to Superman build, it stopped at Superman Omega
I dont use that build at all. But my guess would be they have moved on from kodi 20 and only offer the kodi 21 Omega version now. Which is why Superman Omega is the only choice.
Okay thanks, I appreciate it… I thought it was a bug or something. I guess I have to continue to look for something that’s easy to use for my wife
Ok. But if you liked the superman build why won’t you try the new omega build?
Edit: maybe explain your problem a little better. My assumption was ypu were trying to dl the superman build but could only find the omega version.
That is what I was using before I deleted. I know how to use it, but my wife doesn’t. She liked how the interface was setup on the Superman build. Everything was right in front of her.
I’m going to continue to look at some more builds and see if I can find something that we both can use.
Thanks okay it’s not me. I’m not tripping…. Thanks
Ok sorry. Not familiar with the buld to compare it.
But i like the diggz build. If you want to try it…
I use the debrid version.
I am guesing you know the process. If not TP has tutorial.
I was using the omega version, I was looking for the Superman version 6 titles under it
Okay thanks, that’s my next step.
Search on TP. Maybe others can help you.
That’s alright they have moved on. I’m going to go with diggz also. Thanks for your help
No problem. There are threads on TP if you have questions or problems.
No worries, you were a big help. I appreciate it
No problem. Remeber Troy has a list of builds he recommends. Try others if you dont like Diggz.
To each their own.
My curiosity always gets the better of me…
I tried to dl the Cmbuild to see what the issue was but couldn’t get past the “install from zip”.
I entered the “narcacist” url as troy suggested and did not receive an error message but when i try to install from zip nothing is there.
Its possible there is a new url or they are working on a fix for the current one.
Just my observation. Like I said I am not familiar with the repo/build.
Edit: Found the new link for repo and it worked.
I had never seen the Superman build although I knew that a lot of people used it. Since there is so much extra space on the Onn Pro box, I decided to put on the Troypoint Kodi fork and give it a shot. I installed the Superman Omega build and didn’t care for it. It didn’t work out of the gate like Diggz does and it has a bunch of broken links. The layout doesn’t seem very intuitive. Now, I’m kinda curious what the old version was like.
Man I like that 1! That’s the reason why I decided to go with the Superman build because it was a number 1 choice, nothing worked with it, but everything is working fine with this 1! Thanks again. The only issue I have is my IPTV migration
Id be careful with migrating IPTV. Not sure if it will work well. I once tried to have all the Free TV services linked to the PVR (pluto, tubi, etc) and it caused problems with kodi/build. It basically overloaded kodi and i was getting really bad buffering/ skipping. Once i removed the PVR everything went back to normal.
Enjoy the build!
Okay thanks for the heads up
