Right… I found out the hard way
No problem. You may want to ask/search around TP for IPTV with kodi. I haven’t used a iptv service in years so maybe someone else can help.
I am not a big KODI fan but I’m just getting back into it after a couple of years break, and users that I respect for their skills, and knowledge, with Kodi and Trakt, like @Jayhawks659 and @MarkxG seem to be of the opinion that IPTV is not that good in Kodi. I personally use TiViMate for that myself. Others like Sparkles Although Kodi, with things like Trakt and Real Debrid, for VOD, seems to do a great job. At least that’s how I interpret a lot of their info, and from my rather new Kodi experience with, what seems to me to be some great updates, I’m beginning to see why.
Oh and a big shout out to @JPM69 as well. Keep learning my friend, it’s fun.
OMG he is surrendering!
I don’t have any issues myself with it. Everything is working
My issue is the Superman omega downloaded fine but nothing works and nothing ever loaded up
I went to try diggs xenon and the same thing
Are you using a debrid and authorizing the addons to it?
Most addons, but not all, require one of the debrids to provide links.
If the issue is something else, explain a little more.
I tried, no matter what I click on it goes to a blanke screen I tried it o authorize my debris but nothing ever happened all the icons are x ed out I waited for about 15 min thinking it needed to load and got nothing
So you currently have the Superman Build loaded?
Also what version of kodi are you using?
21.1 omega yea it’s loaded
Nvm I’m getting things to load up now I deleted it and re did it
I was going to suggest that. I swear I was…![]()
