Fixing Buffering!
Until last night, things were working well. I only have 2 tv’s. All of a sudden since last night, the both of them have been buffering. that circle is driving me nuts. A message tells me error, HTTPDATA Source Exception. I don’t have a clue what that means. But all day I have been looking at that circle spinning around and it makes me want to cry. I hope some body can help me with this!!!
Are talking about kodi? IPTV? Stremio? etc…?
I have seen this. Its either your provider lost connection to that channel, or if you are using a vpn you need to pick a different location. Check both of those.
I hope this is the correct venue for my issue.
Lately it seems that whenever I try to stream a 4k movie or series, inevitably it will buffer frequently. For some background, I am using a Shield Pro with a 64 gig stick. Also, I try to find a show that utilizes under 10 megs. Rarely, if ever, do I try to play a show that’s over 15 megs. I always use NordVPN and with it on, I still have a download speed above 150.
I always shut down by clearing the cache on both internal & external storage. Then I’ll clear the cache using TDUK App Killer and Cache Cleaner with reboot of the Shield. I even do overkill by also using Fast Task Killer.
This process is my daily routine so I always start out with as little memory/cache used as possible.
It seems to me that with the above I should never have a buffering situation. Obviously I am missing something. Suggestion(s) please?
Can you help me with a provider for me I have a fire stick and a Onn my provider buffers constantly I have check the speed the router and the modem I think I need a better provider thank you
you are clearing any content on the stick also before trying to stream those large files?
become a Patron and you will have access to the private iptv section
