šŸ› ļø Fixes for Addons/Dependent Files Etc. Not Updating/Installing in Kodi
Moving forward I’m going to do more quick videos like this without audio because I can do them quickly and explain my steps in text.
Issue:
You will see that I tried to replicate this problem by installing Elementum into TROYPOINT Kodi Fork and I had same problems @elginherd had.
Updates were failing to process and dependent files weren’t installing.
  1. I always try to close Kodi, re-open to see if that fixes problem. It didn’t.
  2. I then try completely disabling Surfshark and bingo! Everything now installs and updates properly.
  3. I then back out and connect to a different Surfshark VPN server close to my physical location for best speeds and everything now works. You can also try disconnecting current location and re-connecting as it will connect to a different server in that same location but I know that Omaha usually doesn’t have those problems for me.
Regarding @elginherd comment where it worked fine in regular Kodi and not Fork, a restart might have fixed his situation if he’s using same VPN connection.
Either way, I always suggest restarting Kodi if problems and then examine possible VPN issues if running one, change servers.
I did try force stop the fork with no luck. Changing the state of our VPN didn’t occur to me because I guessed that it was an issue with the fork since the Elementum installed normally on the stock Kodi. Anyway, there’s often more than one approach to solve a problem.
