where do i find these codes. m3u and erg?
There are several m3u playlists and EPG’s. Just put “m3u” into the search and you will get a ton of results. This is the first that popped up.
If you want one of the best free playlist I highly recommend: free2view
It contains a number of lists like
Samsung TV Plus
Pluto TV
Stirr TV
Plex live Tv
Local Now
Distro TV
Klowd TV
WatchYour TV
and much more, all in one place.
Hi Miki. I don’t think this link is working. Do you know where I can find an updated link?
Ya that’s over 18 months old. I have a link somewhere. I’ll look.
Try this. I’ll see what else I have.
https://i.mjh.nz/SamsungTVPlus/us.m3u8
That should get ya going.
Thanks a lot ![]()
Is it just me, or… I’m just not able to play the Github playlist. I copy and paste it in to my Smarters on my phone, but it says “URL is not valid” ![]()
Ok, I tried to copy and paste it in to XCIPTV player, and there it worked perfectly. So there is nothing wrong with the link. Must be something with my Smarters…![]()
https://iptv-org.github.io/iptv/index.nsfw.m3u
You’ll have to add your own epgs to it.
That will do for you. Anything else you can search for. Tons of info here using the ![]()
Sorry, I thought the person needed an epg for Samsung.
Oh all good PF. Originally the link I posted no longer worked and it’s around 20 months old, so they wanted an updated one, but so many GitHub sites are shutting down.
Too much recognition brings the wrong kind of attention and prying eyes.
Sure does.
