Filmplus real debrid links
Does anybody use filmplus apk, Recently after latest update , hardly get any real debrid links, before update had lots of real debrid links , just wondering thanks
@Roy61
Try this:
Re authorize your account
Delete your devices in real debrid and re add them
I’ve done all that except the twitter , I’ll search for that thanks
How do you check RDs Twitter acount if you don’t have one?
@Roy61
Try a different app or apk and test the same show or movie with real debrid see what happens.
@Remy
https://mobile.twitter.com/realdebrid
On my other apks cinema hd and cyberflix I get lots of real debrid links , so I was just wondering if people were having same results with filmplus, cause before the last two updates, filmplus had lots of real debrid links, but thank you for responding
@Roy61
You can do that in the app, but you have to reauthorize RD again. To do that open Settings> Login to Real Debrid then Reauthorize RD.
You can also check TP manual, scroll down to section: FilmPlus APK Features & Details
From there you can authorize real-debrid within the Settings Tab of the app:
I’ve done all that , even uninstalled filmplus then reinstalled, unauthorized from apk and real debrid still only get just a couple hq real debrid links no 720 or 1080 p , was just wondering if anyone else is still getting good quality debrid links on filmplus with newest version ,thanks
@Roy61
If you’re trying to watch new videos, sometimes it will not shows more than few RD links.
Try an older video from the last year or so, to see if you still getting the same results.
Pls, note This is a new Streaming App that provides high-quality links for Movies and TV Shows. It works even better when integrated with Real-Debrid. So maybe they only shows the best quality link available. If you try another app or add-ons to see if you getting more RD links. If so then is nothing wrong with the app and your RD subscription.
I gave up on filmplus about a year ago…was one of my favs. I have better luck with stremio
20+ Best Streaming Apps in May 2022 (Ultimate List for Cord-Cutters)
Greetings @Remy, I also don’t have a twitter account but there are a few accounts I like to follow such as Real-debrd, Troypoint etc. What works well for me is an app called Fritter and you can find it at F-droid apk store. Have a great day!
I am looking for a similar solution to Cinema HD. FilmPlus appears to be a winner EXCEPT I cannot get any RD links to work. I have deleted all my RD links on the RD website and reinitialized each account (it was time to clean up anyway). Every app (Cinema and Kodi) that uses RD delivers lots of links (1080 and 4K) except FilmPlus. I am running the current version from Troypoint as well as downloading the current version from UnLinked (both standard and no adds). Neither of these apps delivers 4K links. Cinema HD gives tons of links. If I am lucky I will get 5-10 1080 P links in FilmPlus. Any ideas on what’s wrong?
@kphillips98
No, nothing you are doing is wrong and thank you for joning us and being a patron.
Kodi, cinemahd and all apps that link with rd will get you most of the same links. Whats happing with different results on different apps is how each app scrapes its torrents sometimes they run into cloud dns issues.
My advice would be to keep a few apps hooked into rd so that way you have options.
My app suggestions are:
Kodi crew and seren
Syncler
Weyd
Stremio
4k links also are not as easy to get ether. As it becomes more available on new stuff im sure they will be more of them 4k links are also bigger in size.
Thanks for the quick reply. After doing a bunch of testing I will keep Kodi as the standard with Magic Dragon and Crew as my go-to streamers. Stremio and Syncler don’t pull 4K links like Kodi or Cinema HD. Stremio doesn’t have an integration to Real - Debrid, but I agree is great for 1080P. Syncler appears to require paying for another service to get Real-Debrid. Since I pay for RD service, I am not interested in paying for another at this time. Very frustrating with FilmPlus, the RD set up appears to be the same as Cinema HD but the real-debrid links are few and far between, so their integration with RD is really bad. Anyway to enhance their integration with RD?
How very odd. I always have lots of 4K links in stremio, although I am unable to watch them as my TV isn’t 4K capable. I’m at a loss to understand why you don’t get 4K links in Stremio, but 1080P is a great enough picture for me on an older Samsung 48" TV.
@kphillips98
You can integrate rd with stremio, there is tons of info on yhat, read the guides troy has on the site and be sure to use the search function.
@kphillips98
Just be sure to set up Stremio with RD on a PC - it’s torture and nigh impossible to do it on an android/amazon device! After that, I guarantee Stremio will become your primary streaming app.
Thanks…I followed Troypoint’s tutorial (great!!) on integrating Torrentio and Stremio and it worked. Actually did it on my iMac. I appreciate your tip, will give Stremio a hard look this week. With 4K links this might be the one to use going forward with Kodi as a back up.
I to only get three or four Real-Debid links when loading movis in Filmplus . That’s it .
@kphillips98
Hi welcome to the community.
If you’re using other devices than only iMac.
Here is a list from TP with the latest update with working alternatives to cinema hd.
