I primarily use Fire TV (4K sticks, cubes, Max) as my streaming device. I used the iMac to set up Torrentio for Stremio. Once that was done, all the updates went to Stremio on all my Fire TV’s automatically, very cool.
As configurations are kept on the server this allows you to go to anyones place who has Stremio installed, and then log them out, and you log in, and your own personal setup is applied immediately.
you are aware, good to hear that. I also heard from other users about the alternatives from TP manual they are very satisfied.
If you like to try some of the alternatives and post your findings we will be glad to know.![]()
I fixed the problem in Stremio with 4K. I installed Torrentio and linked my RD account to it based on Troypoint “how to” documentation. Now I get tons of 4K links. Thanks Troypoint for doing the detail docs.
Pretty sure this topic is cleaned up. Try using stremio if still cant use flimplus, always try different apps that use RD some will work better than others.
