Film Plus TV streams down
i agree i stopped using it better apps around
Not in the last couple of days - got an update late last week. Everything works for me (including the obnoxious ads)!
Yes, it is working fine for me. There was an update a few days ago.
Two questions:
Do you have Bee player installed? For whatever reason, Film+ needs it to function, or to perform better.
I have been unable to update the player for quite a while, though this has not interfered with film plus running smoothly. When the dialog box pops up in film plus asking if I want to update be player I simply hit cancel or no and it doesn’t seem to be a problem.
The other question is whether you have a VPN. Specifically, whether you have Surfshark, which I purchased through Troy point some time ago.
You probably already know this, but surfshark in particular has a feature that allows you to block pop-up ads in film plus. All you have to do is slide the button over to activate it.
Parenthetically, I am not an it specialist, nor am I and it done, but I find surfshark to be both cheap to purchase, and very, very easy and effective to use. I highly recommend the product.
Let me know if you have further questions,
M.
Ty everyone for the info everyone =)
@Grumpyolddog The latest f plus is 2.1.9, two versions, you have to use their player as mentioned in the other replies. Maybe uninstall the one you have and try it, if you have the old one in favorites delete it. I always exit and shut off device for a few minutes before trying any new installs.
I tested TDUK’s encrypted DNS on an Onn, when I did I switched to the official release of Film Plus (from the mod version).
TDUK’s app did block ads, so I continued with it, in fact I went to the official versions of a couple other apps.
The reason I mention this is that the official updates regularly and always prompts me. It’s worked well for a long time. I haven’t had any issues but did with the mod versions.
I reinstall Bplayer and it’s working now. Ty for the help :upside_down_face:
Good to hear.
BeePlayer no longer updates for me, for some reason.
This does not appear to interfere with the proper function of film Plus.
Simply hit cancel when dialog box asks if I would like to update BeePlayer, and proceed do you access film plus content.
By the way, to my knowledge, the film plus updates that appear occasionally seem to work, though I have not confirmed this.
Happy holidays,
M.
It was doing that for me a couple of days ago. Back to normal now.
As long as it works I don’t care.
Took me a long time to learn with IT as in life, if it ain’t broke, don’t fix it.
Happy holidays,
M. :v::gift:
I was having a issue with film Plus.
Foolishly, I deleted downloader, troypoint, film plus, b, bear, etc.
I attempted to get downloader/troypoint from the Amazon app store,
*but it is now telling me those applications are not available."
Any information, insight for advice on how to get downloader and troypoint so that I can reestablish film Plus in its latest version, would be greatly, greatly appreciated.
Thank you,
M.
For Film Plus I’d use APKTime (in the Troypoint Toolbox), Downloader by ATFnews is in the Google Play store or if you search for it in Google you’ll find a link for it too.
Thank you.
I am not using a phone. I’m using a fire stick hooked up to my television. Can I still access Play store / a f TK news (sic) using the fire stick in this way?
Every time I try to select downloader will find the Google Play store on the fire stick connecting to my television, I get the same error message now: application not found.
I don’t know how to circumvent this.
Help?
So I just went to search (magnifying glass on menu bar) on my Firestick, typed in the letters down and downloader came up in the terms. I searched, Downloader is there and I can get it. Are you saying it’s not in the app store on your Firestick?
Next I opened Silk (Internet app) on the Firestick, searched for downloader app, found the link to Amazon (Downloader - App on Amazon App store)
You can download it from Amazon.
I think perhaps surfshark got in the way. I turned it off and now I’m able to get to down later from aft news.
Thank you for responding, both you and mickey, and I’ll let you know how it goes.
Okay, everything is back up and running. I had previously installed Bear (sic). And did so again this time, after installing APK Time.
Something or someone in film Plus assures that bear is the best way to use film plus these days. We call again, I now have APK time and Bear.
Can I simply uninstall Bear without any conflicts?
