Expand Internal Storage on ONN $20 Andriod Box?
Hey Nomad I have TiViMate on my Shield and SK1 and have no issues recording at all, whether a single show or a repeat daily series. If you can get at the System picker you can click it and follow the onscreen prompts. You’ll most likely have to set up your own recording folder and give access permissions. Just read and follow the on screen prompts. The “use this folder” button is down the bottom. I had to use my air mouse on the SK1 to be able to highlight the button at the bottom and click it, then accept the permissions.
Thanks. When I click on system picker it errors saying it isn’t available or something to that effect. So, might be another issue of the modded version for them?
It has recorded shows so far, though the first 1 hour show from Sunday night only recorded 22 minutes. Of course only able to use the free space remaining on the Onn until I can get it to use the USB.
And it also has been recording a daily show trial setup for 30 minutes no issues.
I did clean out some space, thinking that might be part of the issue.
Did you try that? Did it work? I have similar issue. I can see it and move data, but can’t move programs or anything like that.
I don’t remember what I posted in this thread :question::question:
It was Jan 2024. 1 of 4 devices wasn’t acting correctly. Did you reset it and did it fix the issue? Before I try that, want to know if you did and got better results.
IIRC, one of our ONNs USB sticks malfunctioned or the device froze.
I did reset and basically started from scratch with a new stick. It’s still working very well on my wife’s TV.
