I would start with the easy stuff. Clear Tivimate cache, maybe even data (be prepared to reenter credentials if you need to try this), force stop Tivimate, restart firestick, reboot modem and router. If none of that changes anything, I would see if your credentials work on Smarters or an equivalent, to pinpoint the issue to Tivimate. May have to reinstall Tivimate at that point?
I have been having this happen quite a bit in recent days. I found I actually had to change my server location. I went from Dallas to NY. and problem solved.
pan is absolutely right. Samsung, pluto, plex, Redbox, Tubi, Vizio and a few others have legal m3u playlists you can use without a VPN if you want. I still won’t connect without an active vpn, free or not.
Hmmmm…dang this is a real head scratcher. You reset everything, a verified code works in Tivimate on both networks. I’m not sure what you could try next.
Was your vpn on or off during your IPTV on your network with Tivimate issues? You have tried your IPTV service on a different IPTV app and it works or doesnt work on your network?
OK…good…that eliminates Tivimate as a problem…& you’re having no trouble with all your paid apps…so…what’s left…? A 401 code basically denotes an authentication credentials snafu between your ISP & the servers your trying to connect with…which is your IPTV service…for some reason those two aren’t getting along & don’t want to connect. When you set up a hotspot, you’re bypassing your ISP & connecting via your cell service. I’m guessing the problem lies with your IPTV service, as all the other apps & the PlutoTV url playlist you put on all work fine thru your ISP.
