You could always try being brutally honest with your ISP like @Miketheman lmao. Ask them straight up if they are blocking your unverified IPTV service.
I guess it is possible…but improbable IMO. You could always do a free trial with another, or several other IPTV services & see if they work. Personally, I’d contact your current IPTV service & quiz them. Another thing you can try is: pull power to your streaming device, your router & modem for 10-15 seconds to clear out all the memory…power them all up again & connect to your IPTV service thru your VPN only. If you try that…let us know what, if anything different happens.
If your IPTV service won’t work with you to solve this, then they likely arent worth keeping anyway.
I would suspect with that error message its a bad hanshake or dns error. The dns could be the isp. A work around or possible fix is swapping the dns out. This is only posible with a router that has that option.
try another player…
