EPG playlist for Pluto tv
Is their a EPG playlist for Pluto ? I have it on TiVimate but the EPG for it isn’t very good .
I found a few but they may take time to update. None were worth sharing imho.
Sent you a DM with some epgs
Btw, I have 24 epgs installed and they are all assigned to all my playlists.
so with that many is your guide fully populated? any chance of getting a few to try out?
For that lame Pluto m3u I have 100% epg populated. However, almost 2/3rds are just place holders.
I just now downloaded the Pluto app from the Play Store. Other than the UI is somewhat flashy. The channel’s epg is mostly place holders also…
Tbh, Pluto is just good enough to keep around if you have ABSOLUTELY nothing else to watch.
Place holder = basiclly the name of the channel repeated. There is no description and you will be lucky to get just the episodes numbers.
Not a big fan of the Pluto app or the m3u.
Btw, if you are asking if my epg is fairly complete. Then the answer is yes for 10 playlists I have installed. All of the playlist’s guides are well into the 90 percentile complete.
Hi, thanks for the reply I have only 3 playlists I use and added 2 epg’s given to me which from what I see is ok, one is from github, long address and the other I think is from apollo site. Can you point to some good ones to track down?
Send me DM also please of epgs if you don’t mind
Also
I guess pluto shut down the Plylist URL code from working in tivimate. No longer works.
Or is there a new one to use.
what is the epg for Pluto tv?
Just use the m3u8, it has an epg built in.
https://i.mjh.nz/PlutoTV/all.m3u8
Is that still working after the copyright infringement and Github takedown of that Pluto m3u playlist? I guess I haven’t tried it since.
Still working for me with full epg. Just have to update playlist after install
https://i.mjh.nz/PlutoTV/all.xml
https://i.mjh.nz/PlutoTV/all.xml.gz
So what became of this, just out of curiosity? Pluto TV M3U Playlist is Extensive Copyright Infringement According to MPA
Did Github take it down for like a week and then put it right back up? lol
Apparently, there was a dispute with a couple of channels Pluto complained about and I believe Matt took them out and reposted the m3u8.
but not certain about that info.
I really miss being able to plug in the m3u8 for Pluto and Tubi to incorporate those channels directly into Tivimate. Has anyone reposted them or is there new coding that’s come out to do this again, or should I just get used to using those apps directly?
PPL are working to find ways to do what we use to by generating m3u8 lists by legal means. Unfortunately this presently takes some learning.
