EPG for IPTV Explained
Oh the instructions I just gave was for enabling the EPG source on the playlist, not for assigning an epg if the original playlist doesn’t have info. One step at a time. If long pressing on a channel, then selecting Assign EPG and you want to search through the added EPGs as you may be like me and have up to 10, the easiest way to do that is then to scroll to the right and click the binoculars which then gives you a Full scan accessing all EPGs, then search for the channel and as you suggested use the call letters. Tx @Jayhawks659, always good to get more helpful info.
I’ve tried EPG editors and found them too complicated & confusing, so I tried MYEPG and I really like it; but are there any other downloadable EPGs, paid or otherwise, that go longer than 3 days, ideally 7?
(post deleted by author)
