DOWNGRADE Stremio to fix upgrade problems
When I install stand alone none of the links show up for Torrentio. So you are getting links in your stand alone config? Are you sure your sources weren’t coming from Duck Streams?
Nope, stand alone Torrentio addons. RD and PM.
Maybe Torbox issue. Will try RD.
Looks like this issue was on my end. Surfshark blocking it. Weird it’s not blocking Torrentio when using AioStreams or Duckstreams.
I was just about to send you a screen showing that RD and PM found 37 sources above 1080. Try a server in Vancouver.
At the risk of heresy, last night wife was watching Stremio w/RD and I watched another series in bed using Bee TV without any Debrid … and it played without buffering and closed captions matched perfectly.
There was life before debrid!
I no longer use the internal Exoplayer for that very reason. Just Video Player does English (Forced) perfectly.
I was testing on PC version. Using SS Dedicated IP. I changed to different location and it worked fine. As I mentioned before I don’t use Torrentio any more and I only configured Stand Alone and Bootstrapper for testing purposes. If other people having issues with Torrentio with SS turned on then best to try different location or setup in AioStreams/Duckstreams.
My Stremio isn’t working. It isn’t loading any add ons except for USA TV. I’ve tried downloading older versions and it’s still doing the same thing.
