Is anyone else having a problem with Crew? It was working yesterday day. I can open it but I can only watch Porn! lol. Thanks in advance. ACSlater
Ya i having same problem no sports
Just tried it and it works perfect. Now I only use a build that has the Crew only. Nothing else. No sports, nada! Sports come and go unless you want to watch professional handball from Pakistan. Just pulled up a movie, a recent one, and it pulled over 40 1080p sources. I don’t pull 4K because it causes buffering at time and my speed isn’t that good
Watching a TV series on The Crew as I write. Working great!! Hope you get your issue resolved
Just tested The Crew Add-on, everything works fine, movies tv shows, sports, iptv.
Also Ghost this is another add-on inside The Crew Repository working to.
The best thing to do to get it working is update it. Go to Add-ons> Install from Repositories> Navigat to The Crew Repo> Long press on Ok from your remote> Check for updates.![]()
I’m glad to help.
Please you can post the comment here that solved your issue. This will help other users as well. ![]()
What matrix said to do worked for me thanks alot
The crew is not working for me, when I try to load movies it says loading but when it done it says no info available.S but right at the top line where the time is the line says The Crew 17. Maybe it needs an update not sure how to get to the update file. Ow right at the top line a error message came up about connections issue but it was on for just a short time.
Hello, welcome to the TROYPOINT Insider. Please read the rules and regulations prior to posting another topic. Thank you.
Please use our search function regarding this further.
Also this topic/issue/problem/ or common thing as been discussed a lot and there is many topics on this, please use our search regarding this further. Making the same topics on info that’s already posted is against our rules. Old topics are available to post as they are not locked, our search would bring this up. Thank you for understanding.
I got tired of Crew not work. I use paid service for $10/month. It’s not perfect but is way better
I binned the Crew off months ago and use Scrubsv2 for TV shows and movies…for sports try Mad Titan or loop23…
