After installing the Cman wizard repository it wont build when I click on the build repository prompt. I get a could not connect to repository message
I am on the install from repository and it says “could not connect to repository “
I have seen this enough in here to assume the repository is down for some reason. I installed it a couple weeks ago just fine, something must have happened on the developers end.
I installed it fine a week ago, but now I am getting the same error message. I hope it gets resolved; I liked that build.
Same problem , loaded it twice . Same message , could not connect to repository. I uninstall it and reset Kodi , still doesn’t work. Will try again end of week
It seems the CMan Repository is back and functioning properly. Enjoy!
Hello all. It appears that the Cman repository is down again. The " could not find repository " message comes up.
I just encountered the same issue. The video tutorial has a different build version.
Currently it is the 2.0 and wont connect. Has anyone offered an alternative suggestion?
Yes I’m having this issue as well. Just says it cannot connect.
I gave up and just installed a couple
Of other add ons individually
The repository for cMaN’s has been down for about four days.
Is it just me or can others confirm?
You can still install the repository but you cannot install any add-ons
Have you checked his Telegram channel?
Make sure you have correct url, just tried this one and it’s working
Can you install add-ons?
The repository installs from the URL.
I don’t have a telegram account
Just tried Quicksilver and it installed properly.
Well I’m perplexed.
For some reason the repository is not accessible for me.
What version of kodi are you using? Update to 21.2 if you havent yet.
Kodi 20 and earlier may not be compatible.
Good call that is probably it. I’m still using 21.1. I’ll test it out later tonight.
You can try but 21.1 is still part of the Omega version so the Repo should be compatible.
Repository still not accessible for me after updating to Kodi 21.2
Installed Quicksilver as well from the Cman Repo.
