Clone a device tool?
Anyone know of a tool to clone a device for later restore or duplication to a like device?
I need to build 5 Onn boxes setup identical. With computers we use cloning software after building a master. Would be great to have something like that for these boxes.
It would also help as a restore point when an app goes sideways.
What I do is make my own Unlinked store to have a backup of the Apk’s I like, And I can setup android box’s with it.
What I would use would be unlinked https://unlinked.link/ Make an account. It will give you a personal code to access your store. Then make an account at Dropbox to Host your files.
https://www.dropbox.com/
Google images, if you want to add an icon.
https://images.google.com/
When you start adding your files to unlinked you have to change the very end of the URL from. dl=0 to raw=1 Or it will not download. Good luck works for me.
Thank you for the unlinked tip.
I started building a toolbox page like Troy’s but maintenance is difficult.
I’m fond of ATV for the GUI and tvQuickActions for buttons. Both I believe offer a config backup function but I’ve never gotten that to work. Would really be nice for the tvQuickActions.
I used LocalSend based on a recommendation from TXRon. It was easy to use. However, It doesn’t keep app settings.
LocalSend >> Share files to nearby devices. Free, open source, cross-platform
https://localsend.org/ 68
There was a long discussion on this thread that included cloning. ADB AppControl >>> tweaking tool
I’ve used Local Send a few times now and it works great
Me too, I used it this morning.
A lot of options to help quickly grab apks, local send does work well and can go from windows to android if needed also. I still prefer just staying logged into a cloud account on my file explorer and saving the apks there. It is my favorite way to link all my devices together in that regard, and i also use it to save my modded m3us and can apply changes quickly to each device.
Sounds like a great way to stay on too of things. But, thats above my techincal skill. :joy::joy::joy:
I purchased a new Nvidia streaming device. I have an existing video streaming device. Is there a way that I can download all the apps and information on my existing Nvidia and transfer them to my new Nvidia device? This obviously would save time and downloading every app on the new device. Thank you.
