Cinema HD v2.5.2 APK Pros + Cons
At first real debrid had errors. But uninstalled and re install and it works. But the links seem to take forever to come up
You just have to wait and it will come up.
Miki is right set it up on A PC for real-debrid API intergation. Once you set it up there download the app to any device and log in with your account and it will carry your settings over. Miki taught me this last year!!!
I look forward to your test results between the two versions (when you get motivated :slight_smile:
Im still using 2.4 version and it works just fine for me.
can you please tell me the short code to get the cinema hd app? thanks in advance i know its on a different app with several options for live tv
Start reading from the start of this thread or use the search function. The code is mentioned multiple times.
Search Is Your Friend...!
Deleted
thanks
Amazon wants me to delete cinema says it is not part of their apps has anyone seen that message before
it has been updated 31 December 2025 working great
If it says “Launch anyway” then go ahead, you’re fine. If it just says “dismiss” then you’re SOL.
so this sould be easy to downdload on a google smarttv? Since firesticks are not allowing cineama and other 3rd partys , I can download it on a google smart tv?
It’s Amazon (Firestick) that is the problem, not the 3rd party app (Cinema).
Walmart sells the ONN boxes, buy either the Pro or the Plus and you’re gtg.
Do a factory reset on your Firestick then discard it … Yes
Happiness ensues :star_struck:
I’ve seen it, I just skip right over it and start Cinema.
I get a message that says App Disabled from the stick. The message says: this app has been disabled because it uses or provides access to unlicensed content. To remove the app and recover storage on your device, the left uninstall below.
I uninstalled it and went through APKTime and still got the same message.
Is there another way I can install it?
It has absolutely nothing to do with the installation, it has to do with Amazon blocking.
Hello, use Stremio instead. It’s much better than Cinema anyway.
