Cinema HD replacement
Is there another apk similar to Cinema HD? I like their set up (easy to use) and I need an app that I can see my tv shows in one place.
I am using Firestick 4K.
Thanks so much.
Hello @LadyWolf I would suggest looking into FilmPlus as it is very similar and they are constantly updating it.
I use BeeTV and FilmPlus. BeeTV has more streams than FilmPlus but both are very good. Neither is quite as intuitive as Cinema but Cinema is going down fast.
Thanks! I will try them both. :slightly_smiling_face:
Agree. We switched to BeeTV when Cinema went down & I think its comparable for the most part.
I’m still cyberflix works great for me
I don’t know why the need to replace it. It works better than ever for me! New content keeps getting posted, and I find movies I can’t find elsewhere. (those old Errol Flynn movies, for one) and film plus doesn’t work with RD, even though I have it. I will keep using Cinema until it dies.
Like Troy said , film plus. I also like Nova app as well :pirate_flag::pirate_flag::pirate_flag:
One more comment about this.
Everyone always says that Kodi is dead but it’s not.
If you use Real-Debrid, try pairing that with FEN and you will never look back.
No ads, 4K content, mark favorites, support Trakt, etc.
Far from dead, i use seren with real debrid and it’s bumping.
I have RD and the app has the settings to set it up. I haven’t used it yet, however, so I can’t say for certain.
I couldn’t get any RD streams on Cinema. I went through all the steps and still nothing.
When I clicked on one, it was a completely different movie than listed.
Glad it’s working for you though :smiley:
I tried Kodi when I first got my firestick and I found it to be too complicated for me. I have serious memory issues and just need apps that are organized and simple.
I would like to add a huge thank you to you and your team for all the time and effort you put forth for us. I appreciate you all! :trophy::trophy::trophy:
Cinema is back up and working great for the past month or more.
I only learned about FilmPlus in this thread and installed it last night. I found it very good and even found tv shows on specialty networks that Streamio didn’t. Stremio has been my go to since it came out. Always works.
Stremio. Once set up, it won’t let you down.
Syncler+ with Real Debrid is a good option. Also syncs to Trakt, does cost a few $ but worth it :+1:
Stremio also has Trakt integration and you can integrate a premium service like Real Debrid as well as Orion.
Have fun and STREAM ON.
Syncler and Stremio are outstanding. They have more of a “premium” feel than Cinema ever did, but there are plenty of options that use Real Debrid to get you content. Film Plus, Bee, and several add-ons of Kodi are still money with RD, just depends on your taste. If you already bought RD, try them all and uninstall what you don’t like.
That’s interesting… it’s not working properly for most other people(?)
