Just got a new firestick Max - reinstalled CInema HD and it has ads?!?! THe one from my old firestick did not - what did I do wrong - how can I fix it?
Thanks in advance
Hi, cinema is sunsetting do you may want to look at other options. The answer to what u asked the official version does have adds. If u are looking for a add free version try unlinked to get a version that says add free.
THANKS. Yes I am also looking at other apps as well. Suggestions?
You can do a search on troypoint for best alternatives to cinema to get a feel for what the community believe. Bee Tv is a very similar app as one option
Please use our search.
Also there is add free cinemahd but its a modded apk.
