Cinema HD issues on ONN 4k
I installed the latest version of cinema HD on my new onn 4k.When I try to exit a movie it takes me to a game and the only way to get out is I need to reboot the system. Any help is appreciated.
You could try MX Player instead of built in player. Version 3.3.0 is newest version for Cinema.
yes its adds @PapaS has a good idea or look for an add free version
Interesting how some folks have issues with ads and others don’t. I have Cinema 3.3.0 official and don’t have any ad issues (using internal player). That’s on a firestick.
If you read my post I understand it is an ad but my system hangs up and the only way to resolve it is to reboot the onn box. The ad does not allow me to close it out.
Thanks, I did try that player too.
you cant close it out you have to let it run till its finished then you can x it out
That would be great but I don’t have a cursor to move to the “X” the ad just starts over.
only other way is to do a search for add free version there are a few out there :+1:
Thank you :slightly_smiling_face:
Have same pop up but when I hit back click on remote it goes away and cinema re-appears.I seem to recall when downloading this version a option came on viewing options I clicked on one not having any ideas what it was…
Thanks I may uninstall and reinstall it.
That happened to me also, but I just pressed the home key then went to apps and force-stopped the app
Try the TDUK DNS Switcher
Sometimes they try to hide the”X” to exit.
Thanks, I would but I can’t access the cursor so I can’t do anything.
Where would I find it?
I understand. Unfortunately I cant do anything the system just hangs up.
There is a link on this site under the TDUK DNS Switcher thread. There is also a vid on how to set it up.
downloader code 421385
