In trying to watch different episodes of a favorite TV show, there are times when no streams populate to select to watch. Any suggestions as to how I can get more streams to fetch in this app? They do come up in Kodi but not consistent in Cinema HD. I am using RD for this as well.
When Cinema is still working, it has always fetched a lot of sources for newer movies. With some of the older stuff, it can be hit and miss, but your best bet is still using Real Debrid like you are doing. You could try Orion, and see if that increases the options, and/or you can try Stremio. Because it is more of a P2P system, I find that it has more sources sometimes than these free apps. Just a couple thoughts, not sure if they will help, but wish you the best!
try film plus app on unlinked
Please use our search regarding cinema, it’s highly talked about.
Please see this mega cinemahd troubleshooting guide.
