Cinema APK replacement recommendations
Can the google streaming device be used the same as Onn Pro? The Onn Pro is weeks out if ordered. I was just wondering if they (google streaming device) can do what I hear Onn Pro can do?
Thanks so much for the info PapaS!
And the same to Solowarrior & Miki for your opinions. I just love this community and appreciate how strong you all have made it.
Enjoy the Day & Everyday!
I just scanned my box and it has a lot of stuff on it, Flix Vision V 3.2.0r has a 1 out of 77, the plex app from the play store has a 2/77. The highest I ever saw Flix Vision was a 4 or 5 I believe.
The worst I saw was a version of Cinema HQ at a 29, got rid of it and found V 4.0.0 and it scanned a 1.
Cinema HD is still working for me on my Nvidia Shield.
Mostly not working on Fire Tv devices. Android TV and Google devices not affected.
Which onn is the best. I need to replace my Amazon Fire Box, They’re banning my apk’s…
Cinema is working for me on my nvidia shield
Cinema is working for me on Formuler z11 pro has been for years
Cinema, etc, apps will work just fine on any ANDROID/GOOGLE TV box and will continue to do so for the foreseeable future. They will not work on AMZON FIRETV devices as Amazon has blocked them for reasons known only to Amazon (piracy? revenue? legal pressures? misplaced moral code?)
Michael, look to the left side of this site where it says “Troypoint site”, click that and scroll down just a little and you’ll see Troy’s video comparing the 2.
I prefer the Pro, others the Plus. There’s enough information in the video to find the one right for you.
There is tons of other info on the Troypoint site, enjoy!
Sounds like the install is not completing
I would re add the RD API key and install using a PC.
Have found using a phone to install can be hit and miss.
Correct, Cinema HD works fine on my
Android tv, however On Stream is by far the best IMO. And I tried most other apk’s.
Yeah, Cinema APK seems pretty much done at this point. I’ve had better luck lately with Onstream and FilmPlus, and a lot of people seem to be moving to Stremio since it’s more stable and still maintained.
welcome
Onstream was blocked from my firestick a couple of days ago. FilmPlus a couple of days before that.
I’m new on here so would appreciate some help. I’ve used Cinema forever and like how it works. I bought 2 ONN devices when I heard Firestick was going to block Cinema. Unfortunately I only got one of them set up. Once Amazon blocked Cinema forever my family bought the ONN too. After spending all afternoon following the directions to set up the ONN I can’t find the information to add Cinema to it. Cinema is working fine on the one I set up a couple months ago & I have Real Debrid. Is there an update so I can get Cinema somewhere?
I downloaded Film+ but nothing will play no matter which player I pick.
I downloaded Stremio but don’t like it or understand it. Only thing I get on it is options to watch something I can get on another paid for app. What am I missing?
Thank you for any assistance!
FilmPlus ONLY works with Bear Player. It should ask you to install this when you try to play a stream.
Installing Cinema on an Onn box is exactly the same as on the firestick. There are instructions on this website. Be sure to turn on Developer Options, ADB Debugging and turn off Google Play protect.
The bootstrapper setup is the best for first time users. Follow Troy’s instructions.
I gave up on the firestick for any apps that could possibly stop working on the firestick on my main TV, and bought an Android Box, then deployed everything on to it that I needed.
At the same time I turned off the automatic unload with firestick, and as yet have had no problems on a bedroom TV without anything disappearing I actually gave up on Cinema some time back, opting for BeeTV and other apps.
UK based so maybe its just Amazon America and Canada?
