Cinema APK replacement recommendations
And this is the logo for the correct Downloader by aftnews. Also, per Troy’s review,
“The familiar interface is the only thing keeping it on most “best of” roundups. Free links are unreliable without a debrid service connected, and at that point Stremio or Nuvio will give you a far better experience.”
I’ll give it a try. But I did do a search of all APPS and it did not come up. And I forgot to mention that I did look for the aftvnews version. It showed up once but didn’t work properly. After uninstalling that, the next search yielding no Downloader at all. Thanks!
Installed cinemahq, I noticed it won’t let you watch anything until you perform an update. Went to install on another fire cube and when I click install update I get a parsing error. Any suggestions?
Try one of these better options - 5 Best APKs for Firestick/Android TV (Free Movies & Shows)
Thanks for sharing this…me likey. I going to check this out
I installed it not long ago as a backup, same thing I got updated everything is fine now I’m using Rd with it some links are working fine my sub is soon up hopefully torbox will work and be easy to use.with this.:crossed_fingers:
