Cinema APK replacement recommendations
So I bought a shield pro cause I thought my cube wouldn’t work. But now the shield is useless too. Diwnloader won’t let me install Beetv acting just like the cube.
Is the answer an Onn box ? Is that next
You need to disable Play Protect on the Shield.
The Shield will work perfectly right now and for the foreseeable future. Just check your security settings (see Troy’s post, above).
I asked ChatGPT how to turn it off it said you no longer can
This is from askitzme-HI….
Google Play Protect on the NVIDIA Shield Pro can be turned off through the Google Play Store settings. Follow these steps:
  1. Open the Google Play Store app.
  2. Tap your profile icon in the top-right corner.
  3. Select Play Protect from the menu.
  4. Tap the Settings gear icon (top-right).
  5. Toggle off “Scan apps with Play Protect”.
  6. Confirm by selecting Turn Off when prompted.
This disables the automatic scanning of apps, which is useful for installing third-party apps from sources like Dr. Venture’s store. However, disabling Play Protect increases security risks, as it removes protection against malware and suspicious apps.
:warning: Note: Some users report that apps are still removed by Play Protect even after disabling the setting. In such cases, disabling the Google Play Store entirely (via Settings > Apps > Show system apps > Google Play Store > Disable) is a workaround, but this prevents updates to Google apps and may require alternative app sources like Aurora.
For the most current method, ensure your Shield Pro is updated to the latest firmware, as Google frequently updates Play Protect behavior
That’s not true.
FYI: Looks like the Cinema HD 3.0.6 modded version is being blocked from launching now on my Fire Stick 4K.
I guess that pretty much says it all about trying to learn anything on AI platforms!
Shat-GPT… er I mean Chat-GPT aint what its cracked up to be. Neither is Hell-Lexa as far as that goes… She has YET to make me a sandwich OR bring me a single beer :angry:
@Reece ….maybe you didn’t splain it rite….
Maybe I should ask for the FIRST beer instead of the 8th?? (but who’s counting?) :beer_mug: :beer_mug: :beer_mug: :beer_mug: :beer_mug: :beer_mug: :beer_mug: :beer_mug: :beer_mug: :beer_mug: :beer_mug: :beer_mug: :beer_mug: <<(Irish 12 pack! :zany_face: )
Rob Reiner, Rest In Peace.
might be in wrong post .. but new down loader code for cinema hq?
See this - How to Install Cinema HQ on Firestick & Android TV (V6.1)
ask and ye shall receive.. my old downlownloader code quit working. thanks again troys blog and all the rest of you guys that remind me where to look lol
I haven’t had these working for weeks. I am logged into Trakt, all my shows are there, but never any links.
These are the most popular options right now - 5 Best APKs for Firestick/Android TV (Free Movies & Shows)
I wonder why Plex isn’t mentioned?
Hi - I could not find where to start a new topic so hopefully this might get me an answer. Switched out my Firestick for an Onn 4k box. FilmPlus stopped working properly (no working streams) a couple of weeks ago. Downloader not working properly so I uninstalled. First try at re-installing got a page that didn’t look right and didn’t work. Now when I search Downloader nothing at all comes up. I know how to do the search, that’s not a mistake. Do we know what’s happening?? Thank you!
It’s in the playstore. Search for Downloader by aftvnews and uninstall the one you have and install this one.
