Hi, Thanks for the recommendation. The problem is that it will not let me do either - I can’t install & can’t delete.
Ooopppss!
“BUT BUT BUT FIRST install Window to the USB.> YOU NEED to do this via your pc and not use the chromebox yet.” I missed this minor detail (NOT! …It’s a Major step that I missed.)
I am out of town with my wife for a few days, so I can’t test it yet. So, PLEASE wait a bit till I get back.
…as to Android 8.1 x86: Will it be easier to get it installed, and if I can still use other apps/APKs from Play store, then it will be fine also.
Windows tiny11 booted USB 3.1 on the same 12 yr old Chromebook.
Windows boot to follow if you want to see it…
Zoom in to see boot order.
Windows 11,is there.
Wow! I like that. Ok, btw, I am currently out of town for about a week, visiting in-laws…
So, I can’t do anything yet.
But I want to know how you got WinToUSB to do the ‘Windows to Go’ with the Tiny11, since it’s based on a ‘Pro’ version of Windows - and the free WinToUSB will not install the Tiny11 ‘pro’. Did you use a paid WinToUSB? I guess I should see how much $ the paid WinToUSB cost…?
Thank you Miki, for the link.
I installed this version of WinToUSB, and tried to install the ‘Win to Go’ on the Samsung USB drive (see attached screen shot), but it will NOT do the Tiny Pro.
The source file is the tiny pro then I assume you need to choose the flavor of Windows you want, in this case looks like the pro x64 is what is shown. Did you try that? Not something I’ve ever tried. I gave up on Win doze whenXP Black died and at that time we were doing boot discs. Damn I just noticed the free version doesn’t support Pro install. My bad I didn’t check that before suggesting it. Apologies. Not sure what you have tried. Here is some additional reading.
