Build with apps built in?
Is there a build that loads all the best or most popular apps including the adult ones? I know there used to be but I am thinking of refreshing my build but don’t want to have to reinstall all the apps one by one.
@mko
Welcome to our site and community.
I would look here: Mega kodi guide
Check out the link of best builds. Try some of those.
Troy has the best ones updated on there.
So do I have to install kodi first then install one of those builds? Its been a while since I built a stick from scratch. Anyone have experience with a certain one? Want to have some of the adult apps in it too.
@mko
Those builds will not work without kodi installed.
Yes you have to install kodi first.
You don’t have to use a build. If you use a service like real debrid you only need one or two add-ons. It will work faster and take up less space. It just won’t look as cool. Check out the Kodi mega guide on here and click each of the links in there.
