I’ve purchase Nvidia Pro. It’s a bit expensive, but is absolutely the best for IPTV.
I just got my OnnTV box. I jailbroken it added a couple of apps and i want to give it to my nephew for a present. I cannot logoff my google account
It tells me i can remove my account and the Onn will be reset to factory. I will lose thw apps i just installed. Is there a way i can logoff my google account and keep the apps i installed on the Onn Tv box?
Can someone help me with this matter?
Hey @JMan ,
I never tried to delete my account so i cant say if there is a way to do this. I know from past reading that people have set these up for others just not sure of the specifics involved.
Try to search some of the Onn 4K/4k Pro topics already created.
I atrached a link for you to ask there but there may be one better suited for you question.
For those of you into more premium devices other than Nvidia Shield, check out the Troypoint thread on the Ugoos SK1.
I was promised delivery this week with a confirmation e:mail. Hasn’t happened. 17 days and counting. I do not recommend buying an SK 1 from a foreign seller, at least not the one I ordered from.
After your experience, I probably would not order abroad either. I lucked out, receiving my 2 separate orders within 3 weeks and 8 days.
i had buffering issues on apollo, i just changed the player and it made a huge difference, i think i had it as exo, then went to vlc, it made the difference.
