šŸ† Better Alternative to Real-Debrid & Premiumize? + Less Expensive
Good morning Hello Troy.
Thanks for the video. Thanks for the video. So I can ditch real-debrid and premiumize without any problems? Sincerely.
@jpp974….if it was me, i would not ditch my other services just yet….i would wait for @TROYPOINT to do his Full Review, and in the meantime, read all the comments in this thread to get an idea what other TP members are thinking–you know–pros and cons–how to pay for service…etc. etc. etc….but the choice is yours, Good Luck whatever you decide….
Thank you very much for this wise advice. Thank you very much for this wise advice. :+1::pensive_face:
You can get around the crypto issue by turning off your VPN while trying to pay for an account. Then things like PayPal etc will show. You will need to use your proper info to get it though.
Anyone know if it works with weyd?
Hello, this was my first impressions video so I haven’t thoroughly tested it. I will be coming out with a full review within the next two weeks once I’ve done that. From the short amount of time I have tested it, no problems whatsoever.
Works excellent on Weyd but you have to have lifetime sub. Also you can access Torbox cloud and play any files inside Weyd.
In Syncler, if you use multiple debrid services, you can set the priority of each service.
For instance, you could set it like this…
Real-Debrid = 100
Premiumize = 99
Torbox = 98
In other words, assign the highest number to the service you prefer.
You can find this section by going to Settings>Third party accounts/services>ā€configureā€ under each of your debrid services.
I’ve done this and tested multiple times. Logically, these settings should work and sources from all three seeders should be pulled.
In my case, I had RD/100, PM/99, and TB/96.
I also had to PM unchecked as to pull sources despite if RD failed or not.
I still only get RD and TB pulls. I’m going to test it again by logging off TB and see if RD and PM sources pull again together.
Everything set up perfectly following your video but I get the following message and nothing happens:
External providers are enabled but no provider was found
Hello, I don’t know if you are using Stremio or Umbrella with Kodi but if using Umbrella you need to make sure that you install CocoScrapers and enable it. I go through that in the Umbrella tutorial that I link to below the video above.
Hi, great video. Do you have to use stremio or can you just add it to kodi? Can you use torbox with cinema?
No Torbox on Cinema, works with Stremio and a small hand full of Kodi addons are compatible withTorbox also lifetime sub buyers for Weyd can use Torbox.
. Last night I gave it a test and was honestly disappointed. Scraping was slow, (Instant) in TorBox was slow to load and play, speed test took forever to run and I could only get 16Mbs to the TorBox servers, and the highest res it scraped was 1080. Then after testing for several hours I gave up. Then this morning I tested it again. Speed test took just a couple of minutes to run and they have around 20 servers spread throughout the world, and this time I was getting speeds of 150+Mbs down. Like day and night. I switched to the recommended server, after the test, and was absolutely blown away. I really can’t think of a reason why things changed so much in just under 12 hrs. I did not go the bootstrapper route and honestly don’t see the need as TorBox has a huge number of sources to scrape. They also say no VPN needed as they do not record or store your IP address. I still used my Proton VPN though.
I do want to emphasize. TORBOX DOES NOT USE ANY DEBRID SERVICE LIKE REAL DEBRID OR PREMIUMIZE. It has its own sources it scrapes and if you go into the settings you will see an alphabetical list of all the sources it scrapes and there are hundreds.
Maybe they were possibly having server issues on your first try @Miki I honestly find Torbox was a little iffy a year ago but has steadily improved with leaps and bounds and usually pick a Torbox link more often than not.
Anyway here’s a link to check Torbox status.
Tx @PapaS I just go into my TorBox dashboard for all of my status needs as well as downloads, APIs etc. There really is a huge number of options and resources. You can even join the Discord group to ask questions and get help. I just read the full Stremio setup instructions and used the search to get answers to any questions I had.
Thanks, Miki, I was about to ask this question. I have PM, and I just purchased TB following the Troypoint video. I’ve got 5 addons, including Torrentio, and I get most of what I want. I tried adding some more with Bootstrapper, but they didn’t come over, so I tried individually adding USA TV. It came up as the only addon I had and it displayed all the channels I could get, but it crashed my Streamio when I tried to open any of them. I’m back up now after reinstalling Stremio with the 5 Addons and two debrid services. Another lesson for me in Streaming 101.
I have Weyd and use Premiumize. It works fine, but some movies don’t have CCs and links. Could I use TB and Premiumize with Weyd?
Yes as long as you have lifetime sub with Weyd
After following all the steps in the video to add Torbox to Kodi Umbrella, Torbox was not listed in the accounts settings. Any ideas?
