Best Syncler Provider Packages?
It appears that Syncler scrapes take a long time these days without the best results. What are currently the best provider packages for movies and TV shows?
I don’t use Syncler but this should help.
You won’t approve of my Syncler tattoo then? :stuck_out_tongue_closed_eyes:
Thank you so much for helping me out.
It’s why we’re here. We love helping others learn a bit more. It’s fun and @TROYPOINT has given us an excellent medium to do just that. Don’t be shy, post any new questions or use the :mag: . You’ll be surprised how huge the Data base is.
I stopped using it for the same reason. I think you get better results if you pay for the premium service.
@Miki encouraged me to try Stremio. I must say I love it and its my daily go to for streaming. He even helped me with the setup
Syncler+ is definitely night - day difference from free Syncler. Stremio is great also - once the adons are optimized.
I have Syncler +. How does it compare/differ with Stremio? I really only watch movies and TV shows.
That’s the focus of Stremio for me. Movies and series. The one huge thing I like is doing all the config with my cell phone on line as copying the API key and pasting it into the Torrentio addon is much easier. Once completely configured you simply install it on any of your other devices, open it, log in and your entire setup is automatically applied, including your library and what you’ve watched.
Both are very good and offer about the same content. Stremio is easier to set up, but imho, Syncler+ has a little better UI.
Bottom line, Both are very good and offer similar content and accept RD. Stremio is free and easy to set up. Free and easy is my pick
Then is Stremio more like Kodi?
Not really. It has addons similar to kodi but no need for all the typing and once configured can be installed and logged into on any device without added configuration input from you.
Interesting. What addons do you recommend installing for movies and TV shows?
My main one is Torrentio with RD. But there are others I add just for additional options.
Thank you!
Since I already am a Netflix subscriber, is there any advantage to installing it in Stremio?
Many movies are netflix ones the scrapers find. I am not a netflix user at all. So it’s all personal choice.
You don’t really install Netflix separately it will be a section among the other sections.
Thanks. Does Troypoint have a Stremio installation tutorial?
Yeah, scroll up a little bit in this thread.
Ok. So I do love Syncler+ for the fact that my wife can use it. lol. However, there is a show that just came out called “Found”. Syncler can’t find links. I can get it on The Crew from Kodi.
I tried squizzle, jackedup packages. No luck.
Some of the other packs say fail to installed like
Openscrapers
https://support.syncler.net/develop/sou
rce-provider-package
AKi07
https://github.com/itzAki07/scraper/blo
b/main/scraper.json
Curious to see if any of you can get this TV show on your Syncler+
