Best Syncler Provider Packages?
I found 3 episodes counting the pilot in Stremio. Plenty of quality sources. This is the Shanola Hampton series. Hope that’s right. Plenty of RD links for 1080.
For whatever reason, Syncler+ has no sources of this one. Stremio does have them, like Miki said. I dont have enough time before work to test and see why, but will look this weekend why Syncler+ is not pulling them.
I found season #1, 3 episodes on Syncler+. Below are the packages I installed.
Edit: it seems all the sources “Failed Resolving”. I tried all 3 episodes.
Edit, edit: I checked Stremio and as Miki posted it is there (season 1, pilot, episodes 1-3. I did load up the 1st episode and it played without issue.
Edit, edit, edit: I found a way to get the episodes to play using Syncler+.
Go to settings>Debrid Manager>select show>select show again>Play
This method worked and the episode played without issue.
Did you scrape usable sources? I just tried it quickly, not even Orion sources came up. Will dig into it after work.
I did check and they failed resolving.
Most likely will be dropping Syncler+ when my sub expires and stick with Stremio.
I did find a way to get the episodes to play using Syncler+.
Don’t hear many people using Weyd, but “Found” is on there and it plays.
What does this setting even do? LOL.
Don’t know? It’s the first time I used it. lol
Thanks people. I will mess with it more. My wife don’t like change. I can use the stuff easily enough, other apps and what not. Just trying to get stuff set up for her. Trakt is a blessing for the Syncler+. Will have to look into the stremio
So what Stremio addons give us the movies and TV shows we are searching for?
I posted the link near the top in this thread. Have a look.
Got them! Thanks. I will using a Nvidia Shield pro. How will I install the addons? How many can I install that make sense?
Install Stremio, log in. Once installed just open the link I gave you, select the one you want, click install. As easy as that. Add Torrentio it’s one of the best, then any others you want. If you have RD you can add it in the Torrentio addon.
Yeah. Got the Stremio installed got torrent installed. Uninstalled the other unwanted addons. Thought I got my my Trakt installed. I can’t find my lists on the stremio app for nvidia shield pro or S8+ tablet. So any help be appreciated.
Also used to be a big fan of Cinema app. Then went to Syncler when Cinema went crazy for a bit. But I remembered why I left cinema app.
Every time I back out of an episode or movie the screen goes grey and I need to go to app settings and force stop/clear cache. Annoying
I’d really like to give Stremio a chance. However I don’t see anything on Troypoint other than just basic install. What am I missing?
I don’t use trakt. But it’s in the settings of the app. Do a search :mag: for “Trakt in Stremio” and you’ll find a bunch of threads to read on how to enable trakt.
That’s the instruction and all you need. Once installed you go to Settings as you would with any new app and look through the options.
That gives you all the addons you could need. Choose one click on it, click install and you’re done. I have Stremio installed on my phone and do the addons and RD integration there as it’s much easier. Once you configured it on your phone you install Stremio on any device you have, log in and your addons and settings are automatically applied without any further input from you.
Did this download the file from the torrent, is that why it worked? I went into Debrid Manager…maybe I am ignorant to what those are but I did see where it looked like it downloaded the MKV file and I was able to play also.
No, it did not download. It streamed, but there is a way to download it. O started to, but canceled it.
I got a QR patch on my Nvidia Shield Pro when tried to open Stremio. do I have to open a Stremio account on my computer?
You can do it on ya phone if ya like.
No, but I highly recommend doing so. It makes setting up a whole lot easier.
