Best Kodi Addons for Movies?
I had trouble with Crew showing future movies in search. Changed to Asgard. Seems great.
Does anyone know if affenity is still working , In the repo has 3 addons , 1 being infinity , not affenity , any help appreciated ,thanks
i don’t know about infidenty but i am using the collation and that’s working fine for me if that helps
ta for reply phil…
I’m not certain about Affenity as I am still using Fen which has been working for me. So I would assume that the Affenity addon is still working.
from the devs post on another forum:
afFENity is based on a very early version of FL. FL is amazing for what it accomplishes outside of the “normal way” of doing some things in kodi (mainly settings related). however, my preferences are different. mainly I just wanted to see how fork-able FL was at that point while still being able to integrate the changes I prefer (mainly no external scrapers req/file size filter).
afFENity received very few updates, it may never get another update (never say never). there is no point in mimicing FL consistently. FL is amazing, just use FL as dev is the best around.
that being said, if you want to install it, the kodi file manager source address (for afFENity only) for the time being will be:
https://kodifitzwell.github.io/repo/packages
this requires “install from zip file,” select the source, select the zip file and wait for it to complete, it may take a bit to download/install.
fyi, Kodi Addon Crowned #1 - #26 by kodifitzwell
Hi
Did a check and cannot find any info anywhere.
Is there an alternative to kodifitzwell i’ve been try for the last 3 day’s to get infinity
https://kodifitzwell.github.io/repo nothing to download.
See post
https://troypointinsider.com/t/what-is-your-favorite-kodi-addon/119887/33?u=papas
Hey Willie, check out this guide: POV Kodi Addon on Firestick/Android TV (New Install Update)
Not tried it yet but it looks good.
Thank you bruv you’re a gem.
Ok all done just like to add on Kodi preferences on a Shield Tube i had to “allow Kodi access all the the time”
Otherwise the download don’t show when selecting “only when using the app”
