Best Downloader Codes
Originally published at: 35 Best Downloader Codes for Firestick/Android TV (March 2025)
The following guide lists the Best Downloader Codes for installing various Streaming Apps & APK’s on your preferred device. Using the Downloader App is the most efficient way to install applications that are not available in the Amazon App or Google Play Store. However, many do not know that we can input various codes to…
Thank you so much for all of the information that you put out, I have learned a lot since I started following you, however on the post with a code 4…801 it tells me that there was a 404 error that file was not found and I don’t know how to fix this soon so I’ll followed Your video instructions, any help on this problem would be very much appreciate it thank you again and have a nice week
Could you post the actual link/URL to the post please and I can have a look. Thank you.
Just a guess, but I think he’s talking about the Downloader Code for the Elementum Repository which is shown to be 444801 in this post https://troypoint.com/elementum-kodi-addon/
Update, I just checked that code and it is now working again. It was down earlier today.
Excellent post. I noticed a lot of the downloader codes are movie - show players. Maybe a runoff between all of them is due in the future?
I’m afraid I can confirm Downloader Code 444801 for the Elementum Repository is no longer working again. Same error as reported above.
In the Troypoint tutorial from July 1st, on Downloader Codes, there was a comment at the bottom that said that the code for Elementum seems to work off and on.
May 6, 2024
Just a guess, but I think he’s talking about the Downloader Code for the Elementum Repository which is shown to be 444801 in this post How to Install Elementum Kodi Addon (July 2024 Update)
The RB link is bogus, doesn’t work, I think RB is no longer a valid app for TV, the mobile APK sort of works. If someone has better information?
StreamFire and SportsFire change Downloader codes with every update. Current codes are:
StreamFire - 3514876
SportsFire. - 4585605
I keep getting ssl protocol error when trying to download toolbox and My Family Cinema. I have no problems with any other app l. I have downloaded TVimate and Watchlist Pro just fine. I have cleared the cache and data in downloader plus restarted fire stick, router and modem. Is the ssl certificate good for toolbox and My Family Cinema? What else could I check on my network?
@dkrajicek … If you’re talking about the Troy point Toolbox in Downloader, you don’t download it, you enter 250931 in Downloader, then save it as a favorite, and that’s where it stays, in Downloader in favorites…
Yes I am using the code and get the ssl protocol err
Check the date and time on your Fire Stick.
Yes I have already done that also
Sorry to hear of your frustrations. Just to clarify, you do have “Downloader”, on your Fire Stick, correct?
Yes I have Downloader on my Firestick
I’m sorry that I’m at a loss here. Do you have an anti-virus program running?
Also, I assume that you have plenty of space on your Internal Memory? You might try to clear your cache and restart your Stick after that. (OPPS! I just read that you’ve already cleared your cache and restarted. Please disregard,:grimacing: )
No anti virus running on Firestick or network. These are both brand new Firesticks I had to replace some old ones. I also tried on my other Firesticks that I have and have the same issue.
I’m assuming that you enabled Unknown Sources, right?
The only other thought that I have is that the latest Fire OS could be blocking. The “Oh no, you can’t have any of this side loaded stuff!”. Nobody is really certain how things are going to shake out with the changes Fire OS and apps outside of Fire universe.
Yes I have unknown apps enabled. I can download everything with downloader with the exception of My Family Cinema and Troy toolbox
