Best Downloader Codes
Again, just to be sure, you do not “DOWNLOAD” the Troypoint toolbox, you “ACCESS” it. Either using the shortcode or the toolbox url. Remove the brackets( )
troypoint.(com)/tb
Also, a while back Downloader changed hands, not sure if that matters But the logo is different, the Old logo was just a straight down arrow, and the New logo is like a U-Turn arrow….wouldn’t it be nice if that’s the simple solution !!!
As @Miki pointed out I think your issue is you are somehow trying to download Troy’s Toolbox - At least that is what you seem to be saying. You don’t download it, you save it as a favorite in Downloader.
Yes using code to access.
Yes I had to download Downloader first from App Store on the new firesticks
Also as mentioned, be sure you are using the proper downloader app.
The “Downloader” code for SD Maid (982837) no longer works. I get “ The webpage at https://nlt.wtf/nexxus/misc/SD_Maid-Pro-v5.6.1_build_50601-Mod_v2.apk could not be loaded because: net::ERR_NAME_NOT_RESOLVED ” . Any Help???
If you are on a Google based device, then try the Play Store search.
The next alternative is: https://play.google.com/store/apps/details?id=eu.thedarken.sdm&hl=en_US
Or: SD Maid 1 Downloader Code for Firestick & Android TV
Norofire, Sportsfire and Streamfire are gone. For a few months now with no sign of coming back unfortunately.
