Hey there, new to the forums here. Looking to buy an android box as with my IPTV apps the firestick doesnt load very well, or crashes, or they’re slow.
Looking to buy a few of them and want to make sure they’re good boxes.
Any recommendations?
PS, I am in Canada and am looking to purchase them online, through places like amazon.
Hi there. I recommend Ugoos, BuzzTV and Formulier brand Android boxes based on my own personal use. They are well made, with good hardware, plenty of RAM and internal memory, with good heat management, which is very important for the lifespan of your device.
I have 2 T95Z Plus boxes that are 5 years old and work flawlessly. I never shut them down, never had any type of over heating issues or any issue. They have 32GB Storage so I never have had to delete any files or worry about running out of storage. These boxes are made in China and run stock Android. I have been waiting for them to stop working the past 1-2 years but Nope they keep on chugging. You wil find these on amazon.com or GearBest. There’s several manufacturerers and many different spec’s out there. YMMV but my experience has been quite good with them
With the way Amazon set up their firestick you need to turn on developer options and download the debloat app it disable all the system apps that takes up all the processing power
Search for downloader app and install it then type 295427 it’s a shortcut to the debloat app to speed up your firestick
For original question Google Chromecast is good TiVo stream 4k is good choices
Tutorial for using the debloat tool troypoint.com/debloat-toolbox-on-firestick/
On my sister fire tv and her firestick and my cube and fire tv it still works I blocked updates a long time ago my devices probably don’t have that update mine still disable all the Amazon crap only my 2021 fire tablet 10 plus protects the built-in apps
Where are the apps if they are still there you’re lying it’s not in my device storage so I’m just asking your smart ass where are the apps if I can’t disable them. Answer the question where the apps you aren’t disabled yet they are not on my device anywhere
I don’t want updates I don’t want Amazon changing my device and my fire tv won’t go past this and update won’t install but you said I couldn’t disable updates but mine won’t install
Thanks for the suggestion MarkxG!, I have been looking at those as they’re relatively cheap to start out with, and hopefully will help with the wife from bitching her EPG isnt loading. I got gigabit internet, so I dont think it’s the internet being the issue, eventhough I don’t believe my firesticks support it. They’re older firesticks.
@Miki Proud of the way you remained professional with @Chosen1 after the way he/she wrote some very unnecessary and insulting comments to you
[> quote=“Chosen1, post:17, topic:80253”] > you’re lying it’s not in my device storage so I’m just asking your smart ass where are the apps if I can’t disable them. > [/quote]
You are a credit to Troy’s and an example for the rest of us how to keep calm, answer the question, and not get pulled into an argument!!
Okay, this topic got a little off topic here, but @Chosen1 He is trying to help you btw. Can we focus on the content about android boxes and not firestick help? We can make another topic on that if needed or use pm.
@Miki You have been very patient with me in the past when trying to help me and teach me. You’re an excellent teacher and have the patience to explain things over again, even whenever I felt overwhelmed or lost
And you’re correct, sometimes we all have bad days and just let our frustrations which is most likely happened to @Chosen1
Here’s an apple for the teacher!
(Actually ¡¡cervezas frias!!)
