Bee Tv, No ad Version?
Like Bee Tv, hate the Ads…Anyone know of an ad free version?
Thx
Removed due to a malware find in the APK
I wouldn’t download the ad free version from the link above. I tried it out of curiosity and it had a browser ransomware virus attached. Windows defender and AVG antivirus didn’t catch it but I was able to go into task manager and close down Chrome.
I found the apkmody version to be harmless.
Tx for this sktn77 I’ll take the link down.
Thanks. S…Do you have a downloader address for apkmody firestick install?
Thanks , Hitstreak
This is a trustworthy site.
You can use this link:
https://apkmody.io/?s=beetv#!
or the link provided by Miki, above, for an alternate download.
Thank you very much.
Try downloading from APKtime store. Get apktime on unlinked store 96960000.
Thank you for that info
Still getting ads on suggested unlinked link…Am I doing something wrong?
Yes, did the apkmody and tried all 3 listed no ads links and all had ads…
Did you try the site I provided a link to ?
Is it ad free Bee?
Thanks
It says it is. I don’t use these apps I use Stremio and never get commercials in TV Series or Movies. GL2U.
Thanks but is not ad free…
The most recent update of BeeTV and FilmPlus are making it much more difficult to remove ads. Every add-free version I’ve tried (latest versions) still have ads to some extent.
True, thanks for the clarification…
That’s odd. I’ll check it out. Last I checked on Oct 30, 2022 it was.
